LTR 450 K9!!!!
9 messages · 17 vues
Suzuki40 » dim. 18 mai 2008 17:05 #29897
Mais quelle horreur qu'est ils ont foutu chez Suz le designer a fumer ou quoi n'importe quoi le rouge ressemble a un KYMCO
Franchement la concurrence s'applique et eux ils font des grosses boulettes
C'est décevant !!!!!!!!!
Re: LTR 450 K9!!!!
Suzuki40 » dim. 18 mai 2008 17:05 #29915
La couleur du cadre du premier est vraiment jolie, par contre, c'est vrai que le rouge lui va pas top
Re: LTR 450 K9!!!!
Pierro33 » mar. 2 sept. 2008 11:54 #30037
bon je pensais que j'avais des hallucinations en voyant des photos sur un site,mais non....
Re: LTR 450 K9!!!!
caro64 » mar. 2 sept. 2008 23:40 #30136
voilà les specificités du 450 ltr 2009:
New Features
New aluminum seat rail to reduce weight
New Engine
ECU programming and cam profiles designed for optimum engine output especially at low- to mid-rpm range
New countershaft for improved gear shift feel
New Chassis
Front and rear suspension have Kashima coating for reduced friction and smooth performance
Updated front and rear suspension settings with larger rear tires and updated swingarm rigidity balance for improved handling and better shock absorbtion
Engine Features
Race proven four-stroke, single cylinder, fuel injected, liquid cooled, DOHC. Four valve engine designed to be compact, lightweight and provide incredible performance
Innovative Suzuki Advanced Sump System allows the engine mass and crankshaft to be positioned close to the ground for a low center of gravity and also keeping the engine as short as possible
Aluminum cylinder bore is electro-plated with Suzuki's own race proven SCEM (Suzuki Composite Electrochemical Material for improved heat transfer, lightweight and tighter piston clearance
Lightweight magnesium clutch cover, magneto cover, and cylinder head cover for minimal weight and maximum durability
Lightweight and durable titanium valves are used for precise valve control at high rpm and reduced reciprocating mass. Titanium intake valves measure 36mm and 29mm on the exhaust
Lightweight forged aluminum pistons use a 3 ring design with cutaway sides, oil retaining grooves for reduced friction and the oil control ring feature a high performance chrome nitride plating for less friction
Five speed transmission is exceptionally compact for a compact engine layout and superb handling
The LT-R450 utilizes a convenient electric starter for easier starts
A high capacity radiator is used to handle the high performance engine output combined with a compact and lightweight, ring type cooling fan for maximum efficiency
High performance cylinder head features a narrow included valve angle creating a compact cylinder head design, compact combustion chamber and featuring 12.0:1 compression ratio for maximum performance
Advanced and lightweight electronic fuel injection system with a 42mm bore and multi hole type injector for optimum atomization, smooth throttle response and maximum performance
High performance ECM utilizes a high spec 16 bit CPU for quick fuel injection calculations and is designed to compact and lightweight
Centrally located muffler layout for improved mass centralization, perfectly symmetrical weight distribution, and higher cornering performance
Chassis Features
High-tensile steel frame designed for optimum rigidity, maximum durability and features a compact and lower profile for a lower center of gravity and unmatched cornering performance
Race-ready steel swingarm providing more flexibility and a smoother arc of movement for optimum handling performance in any environment
Incredibly wide independent double wishbone front suspension with fully adjustable Kayaba piggyback reservoir style front shocks featuring 40mm pistons and a sturdy 14mm shock rod for superb damping and incredible performance
Kayaba rear shock features adjustable high and low speed compression, rebound and preload with a 50mm piston, 18mm rod and piggyback reservoir design providing 290mm of rear wheel travel
Special Dunlop radial tires designed specifically for the LT-R450 combined with smaller 10 x 5.5 inch aluminum rear wheels and 18 x 10 inch aluminum front wheels for superb cornering stability
High performance dual hydraulic front disc brakes with 160mm front rotors and a single hydraulic rear brake caliper mounted on a forged aluminum mounting bracket and a 190mm rear disc
Rugged Serrated large footpegs provide excellent grip and control
Aggressive styling highlights the high performance nature of the QuadRacer R450. The LT-R450 is styled with a low and wide profile to further emphasize the lightweight performance intent of the machine
The LT-R450 has a GSX-R and Hayabusa inspired multi-reflector headlight that is easily removable with a single bolt and an ultra compact LED tailight at the rear
Special
allez voir sur:
http://www.suzukicycles.com/Products/LTR450ZK9
moi, je prends le noir!!!!
Re: LTR 450 K9!!!!
Suzuki40 » mer. 3 sept. 2008 00:12 #30140
Merci Mariane mais l'anglais gloups alors j'ai traduit les infos que tu nous a données et voici certes en petit chinois ce que ça donne :
Nouveaux Dispositifs
Nouveau rail de siège en aluminium pour réduire le poids
Nouveau Moteur
L'ECU programmant et les profils de came ont conçu pour le moteur optimum produit particulièrement au bas à la gamme mi-T/MN
Nouvel arbre de renvoi pour la sensation améliorée de changement de vitesse
Nouveau Châssis
La suspension avant et arrière ont Kashima enduire pour le frottement réduit et l'exécution douce
Les arrangements avant et arrière mis à jour de suspension avec de plus grands pneus arrière et la rigidité mise à jour de swingarm équilibrent pour la manipulation améliorée et choquent mieux l'absorbtion
Dispositifs De Moteur
Emballez le cylindre à quatre temps et simple prouvé, carburant injecté, le liquide refroidi, DOHC. Le moteur de quatre valves a conçu pour être compact, poids léger et pour fournir l'exécution incroyable
Le système innovateur de carter de vidange avancé par Suzuki permet la masse et le vilebrequin de moteur à placer près de la terre pour un bas centre de la gravité et maintenir également le moteur aussi court comme possible
Le cylindre en aluminium est plaqué avec le propre SCEM prouvé par course de Suzuki (matériel électrochimique composé de Suzuki le dégagement de transfert, léger et plus serré thermique amélioré de piston
Couverture légère d'embrayage de magnésium, couverture de magnéto, et couverture de culasse pour la longévité minimale de poids et de maximum
Des valves titaniques légères et durables sont utilisées pour la commande précise de valve au T/MN élevé et réduites échanger la masse. Les valves titaniques de prise mesurent 36mm et 29mm sur l'échappement
Les pistons en aluminium forgés légers emploient une conception de 3 anneaux avec les côtés en coupe, les gorges de retenue d'huile pour le frottement réduit et le dispositif d'anneau de commande d'huile une électrodéposition de nitrure de chrome de rendement élevé pour moins de frottement
La transmission de cinq vitesses est exceptionnellement compacte pour une disposition compacte de moteur et une manipulation superbe
Le LT-r450 utilise un démarreur électrique commode pour des débuts plus faciles
Un radiateur de capacité élevée est utilisé pour manipuler le rendement de moteur de rendement élevé combiné avec un compact et léger, ventilateur de type d'anneau pour l'efficacité maximum
La culasse de rendement élevé comporte un angle inclus étroit de valve créant une conception compacte de culasse, chambre de combustion compacte et comportant le rapport de compression de 12.0:1 pour l'exécution maximum
Système d'injection électronique avançé et léger de carburant avec un injecteur de type d'alésage et multi de trou de 42mm pour l'atomisation optima, réponse douce de commande de puissance et exécution maximum
La contre-mesure électronique de rendement élevé utilise une haute unité centrale de traitement de bit de Spéc. 16 pour des calculs rapides d'injection de carburant et est conçue pour rendre compacte et poids léger
Disposition centralement localisée de silencieux pour la centralisation de masse améliorée, la distribution parfaitement symétrique de poids, et l'exécution acculante plus élevée
Dispositifs De Châssis
L'armature d'acier à haute limite élastique a conçu pour la rigidité optima, longévité maximum et comporte un profil bas compact et pour un centre inférieur de la gravité et l'exécution acculante inégalée
swingarm en acier Course-prêt fournissant plus de flexibilité et un arc plus lisse du mouvement pour l'exécution de manipulation optima dans tout environnement
Incroyablement au loin double suspension indépendante d'avant de wishbone avec des chocs entièrement réglables d'avant de modèle de réservoir de ferroutage de Kayaba comportant des pistons de 40mm et une tige vigoureuse de choc de 14mm pour l'atténuation superbe et l'exécution incroyable
Compression de dispositifs haut réglable et à vitesse réduite de choc d'arrière de Kayaba, rebond et charge initiale avec un piston de 50mm, tige 18mm et conception de réservoir de ferroutage fournissant 290mm du voyage arrière de roue
Les pneus radiaux spéciaux de Dunlop ont conçu spécifiquement pour le LT-r450 combiné avec de plus petites roues arrière en aluminium de 10 x 5,5 pouces et des roues avant en aluminium de 18 x 10 pouces pour la stabilité acculante superbe
Les freins à disque avant hydrauliques duels de rendement élevé avec des rotors avant de 160mm et un étrier arrière hydraulique simple de frein ont monté sur un support en aluminium forgé et un disque 190mm arrière
Les grands footpegs dentelés raboteux fournissent l'excellente poignée et la commandent
Dénommer agressif accentue la nature de rendement élevé du QuadRacer R450. Le LT-r450 est dénommé avec un bas et large profil pour souligner plus loin l'intention légère d'exécution de la machine
Le LT-r450 a un GSX-r et un phare de multi-réflecteur inspiré par Hayabusa qui est facilement démontable avec un boulon simple et un tailight ultra compact de LED à l'arrière
En gros les nouveautés du R c'est que du pipo et il nous la joue plutôt pour moi tout ça c'est du .
Ils ont oublié une chose importante revoir la boite a vitesse,a mon avis c'était a faire a la place de la boucle en alu ou des amortisseurs qui resterons quand même des origines.
Les pneus enfin ils ont compris au bout de sa quatrième année que c'était de la daube,mais que valent les nouveaux
Enfin on verra bien du moins les futurs possesseurs,j'espère que les boites seront comme les 2007 (fiable) et non pas comme les 2008 (faible) et oui c'est les mêmes lettres mais placés différemment
Une question Mariane tu passes sur R l'année prochaine et le Hyos il va s'ennuyer alors
Cordialement
Yannick
Re: LTR 450 K9!!!!
Suzuki40 » mer. 3 sept. 2008 01:25 #30163
bah ecoute, c'est en projet, on verra..
Re: LTR 450 K9!!!!
Titoutango » mer. 3 sept. 2008 08:58 #30171
Un suze en rouge, alors là je suis déçu en prinicipe c'est pour les quads qu'on voit plus souvent derrière le SAV que la ligne départ.
C'est n' importe quoi, c'est comme si demain superman se pointait dans une tunique verte et orange, plus aucune image de marque , on ne saura plus qui c'est ce con qui vole au secours des gens en bleu et vert et du coup tout le monde se tournera vers cette tapette de spiderman qui se la pette avec sa toile d' araignée. Oui, parceque les gens ne s' identifient pas à une personne en tant que telle, mais à ce qu' elle renvoie, à son image !!! MERDE putain mais qu' es ce qu'ils m'ont foutu les designers Sucekiki là !!!! Ils ont fumé de la laine de verre ou koiiiii !!!!
On dirait du coréen là ou pire de l' amerloc , genre la machine que tu offre à ton gosse à Noël parcequ'il a bien travaillé à l' école ou parcequ'il aime bien jouer aux mécanos dans son garage NOOONNNNN C'est pas Suzuki ça !!!! BORDEL Un suze, ça se mérite MERDE c'est comme un pastis !!! c'est pas en foutant rien de ta journée que t' auras droit à ton pastagas le soir hein !!! Superman lui tu crois qu'il a fait quoi pour mériter sa tunique bleu et rouge hein ? et ouai Mec, faut se la bouger un minimum hein !!! tu crois qu'il est arrivé comment sur toute les vidéos du net hein ??? ET OUAI MEC
Tient parlons-en du net :
Le net, tu vois, toutes les compagnies essaient de mettre dessus leurs propres pubs, leurs propres films, tout ce qu’elles possèdent, dans cette petite boîte.
jusque là ça va mais après ça se gatte
Le problème, c’est que quand tu as fumé, tu ne peux pas sortir de ton esprit le goût de la cigarette. Alors, quand le génie sort de la lampe, il est beaucoup trop gros pour pouvoir retourner dans cette lampe.
Et c’est leur problème, ils ne peuvent pas retourner dans cette boîte qu’est le Net. Alors si tu fais un film sur le Net, tu dois le tourner à l’intérieur de Net, et comprendre les principes du Net. Le Net est stupide … mais intelligent.
Non en fait je m'en care le Q, Suzuki forever
Vais me faire un café moi hein
Re: LTR 450 K9!!!!
Titoutango » mer. 3 sept. 2008 09:48 #30181
JCV............. MDR
Re: LTR 450 K9!!!!
Pierro33 » mer. 3 sept. 2008 10:03 #30182
tu es complètement aware Titou le philosof
les champignons peut-être ???
ou bien la grippe à bière ???
je sais version Titou c'est plutot "la grippe à Pastis"
